- Mar 13, 2003
i just got an old ac unit from my school that is in good condition and i just took it apart and plan to use it for a water chiller in my pc
i have some questions though
-what kind of block should i use will any good waterclock work
-what kind fo pump will pump these really cold temps and isnt insanely expensive
i also have an idea for my waterchilling set up i was thinkign about building a plexiglass case just slightly bigger than the evaporator and mountiogn the evaporator in side the plexiglass case, then having all the warmer antifreeze flow from the top of the plex glass case down to the bottom where it would be pumped out. this way i would get alll the slightly warmer antifreeze that had just gone over the cpu to flow from the top of this plexiglass case entirely over the radioator then back to the bottom
does anyone see any problems wiht this or have any other better ideas
thnx
thnx
