- Jun 8, 2011
- Falls Church, VA
Water Cooled Banchetto I7 2600k build & Server Rack
This build will be located in the server room for mostly rendering/ripping movies and burning blu-rays. It will also be connected to a 73inch DLP 3D tv through HDMI straight into the receiver Onkyo THX-708NR
Specs
The rest of the setup in the house consists of:
Main computer I use at home is the iMac 24 inch with a 23 inch Apple Cinema display.
Runs on Snow Leopard and Windows 7 Ultimate 64 bit.
3.06ghz Intel Core 2 Duo
4gb of ram
500gb hard drive
Laptop is a MacBook Pro 15 inch December 2009
2.53ghz Intel core 2 Duo
8gb of ram
Samsung 128gb SSD (it runs like a dream!)
Run a cluster of Dell 2850 PowerEdge servers at home located in basement.
Dual processor dual core Intel Xeon 2.8ghz.
Windows Server 2008R2 Enterprise 64bit on three and one of them runs on CENT OS.
One of them is a Microsoft Exchange 2010 server
Each one has dual redundant power supplies.
Each one has two gigabit network cards.
16gb of ram on each.
15k RPM SCSI hard drives 146gb each running raid 5 . Six hard drives per server x 4 servers.
4 1000 APC's 1U
Dell 42u Server Rack.
15 inch slide out LCD and keyboard with track pad.
A Synology NAS DS1010+ with Intel Atom and 1gb of ram with 10TB.
Dual gigabit network card. 8 USB ports and one eSata
Running 5 seagate hard drives of 2tb each on raid 5. Model http://www.seagate.com/www/en-us/products/desktops/barracuda_xt/
Able to move write files to NAS at around 115MB/s over network. Setup with link aggregation 802.3ad for a 2gb port speed.
Gigabit switches throughout the house with CAT6 cables and a Wireless Access Point running 2.4ghz and 5ghz.
Still have to setup the new Juniper SRX210h router which has an expansion slot for a 3g card in case internet goes down.
And the 73 inch DLP 3D that the Banchetto will be plugged in to.
Backup generator.
Specs
- Case: Banchetto 101 Revision 2
- CPU: Intel Core I7 2600k
- GPU: EVGA GTX 480 SC
- Motherboard: Z68X-UD7-B3
- Memory: Corsair Dominator GT 2000mhz dual channel 8gb with fan module
- PSU: Corsair ax1200
- CPU cooler: Apogee XT (R2)
- Radiator: XSPC RX360 3x120mm
- Pump: Danger Den DD-CPX Pro 237GPH
- Fans: Akasa 120mm X 3 Apache Black
- Reservoir: Bitspower Water Tank 150 inline
- Tubing: Feser tubing 1/2 id 3/4 od anti kink uv blue
- Fittings: All compression fittings from bitspower
- Fan Module: Still deciding
- Hard Drives: 128gb SSD and 3 1tb seagate under raid 5
- Pioneer BDR206 Blu-ray 12x burner
4gb of ram
500gb hard drive
8gb of ram
4 1000 APC's 1U
Backup generator.
