Currently have pc with an ekweb predator to cool cpu only and a Titan XP GPU, 1000w EVGA PSU. Case is Fractal Design Define S case. Complete parts list https://pcpartpicker.com/user/eco_bach/saved/d6Ff7P
I need to add 1 then eventually a 3rd GPU (total 3 GPUs) Thinking the new 1080 ti Machine is used exclusively for GPU rendering. Currently under load, I can keep my current Titan XP without WC under 60C by manually boosting fan speed. So many questions and options!
For the 2nd 1080ti I could
1 try running without additional WC,
2 get EKWEB water blocks and a 2nd radiator which I could front mount
https://www.ekwb.com/shop/ek-coolstream-xe-360-triple
3 get a all in one solution though not sure if it will fit!
https://www.amazon.ca/EVGA-GeForce-HYBRID-GAMING-Technology/dp/B0713XX64Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1505748945&sr=1-1&keywords=1080+ti+hybrid
Also once I install the 3rd GPU will probably upgrade my PSU to a 1600W model.
What would you do? Any advice or feedback appreciated!
