- Dec 9, 2002
My outside air temperature gets quite high during the summer, (100 to 112 degrees is not unusual), my inside ambient may be 95-98 degrees at times.
So.... Knowing that my temperatures are already high, (on air cooling) and believing that even water cooling cannot go sub-ambient, and not wanting to mess with refrigeration, I am considering an alternate source of cooling.
My concept is to run a water cooled system replacing the radiator with the natural cooling power of soil. Three concepts are offered for peer review.
Here are the three concepts for comments:
1. Replace the radiator with a large coil of buried copper tubing, buried under the house.
or
2. Replace the radiator with a buried steel tank under the house. The tank provides for the heat exchange with the soil, and allows increased btu capacity due to more water mix being stored. (Is 5 gallons enough? )
or
3. Combine both options one and two. The addition of a copper coil allows for an increased heat exchange effeciency.
All three of these options allow the pump to be located under the house so I don't hear it. The tank options (one and three) allow the use of a submersible pump.
Assumptions for each concept:
a. Under the house, there is no direct sun, and the soil is always cooler than the summer daytime high ambient temperature. I'll insulate the lines that are exposed to the air (between the floor and the soil) so that the sysem can't freeze during the winter or gain heat during the summer. (Note: I'm in a region where the soil does not freeze during winter. Folks in colder regions would have to bury below the frost line and insulate down to the frost line.)
b. A larger pump will be needed to handle the extra head pressure and the line resistance for the longer lines and buried components. This will increase my electrical costs a bit, but no fans except for power supply!
c. I own the house, so I can drill the necessary holes in the floor.
d. I can powder coat the outside of the buried components to prevent corrosion. I can also powder coat the inside of the steel tank to prevent/minimize the battery effect.
e. I can include a pressure or flow switch to shut down the PC power if the water flow stops due to failure in the system (pump stops, lines freeze, system leaks.) I have not designed this part of the system yet, but I'm sure it can be done.
f. I have access to a milling machine so I can make my own CU water block, and I can make and powder coat the steel tank.
I need your opinions, what am I mising? Are there other problems that I have missed?
or
or
