- Jan 6, 2003
- I can see walmart, 44906
im having some difficulties at work recently. with the wireles ISP, we have had 2 clients in the last few days that have gone down from water getting into the cat5 run to the roof and corroding the plugs and insides of POE injectors (one was a linksys POE setup for a wet11 and the other a home made POE injector for a senao CB3) and im wondering how te water is getting into the cable. is it somehow penetrating the outer plastic? i would tihnk that if it was coming in through the other end up by thr equipment on the roof or tower it would cause that equipment to get wet as well. but its just coming down the inside of the cat5 and running out into the POE injectors.
could it be because its regular cat5 cable being exposed to the elements instead of using cable designed for outdoor installs? should the cable be relaced? how would we go about sealig up the plugs on the cable to prevent water from getting in and out?
thanks for the advice
