- Oct 10, 2012
- Secret lair
Any benefits to orienting the pump on its side that you know of? Considering tearing my rig down when I replace the pump to possibly redo my layout with the pump but I don't really feel like it unless I can justify it as being better
As long as you dont mount the pump "upside down" ie with the motor (wires) upwards you're good to go.
This makes for a MUCH easier routing of the loop.
The mounting bracket that comes wiht the pump invites to use it as a "stand", but you can actually rotate the whole to mount it on a sidepanel. As long as the axis/bearing is horizontal or vertical (but not upside down) its good.
