CorntoeGoblin
- Aug 3, 2014
Hi guys, I seem to be having an issue with bleeding air out of a water loop. This is my second water cooled PC so I'm not a newbie but after a month of troubleshooting this issue I've broken down and need the help of your gentle people.
The issue:
I have 2 rads(120 & 240) , CPU, GPU, reservoir in a loop. I will manually bleed the lines tilting and shaking the case with a second power supply to the point where the reservoir is empty and no more bubbles come out of the pump. I'll run the computer with a load and after 2-3 hours, the water slowly rises back into the reservoir until it tops out and then the output of the pump gets blocked with a huge air bubble shutting down the PC due to heat. I have no idea where the air is coming from as I modified the tubing so that it's impossible for the air to go down from the reservoir back into the loop. The pump is extremely noisy and it'll go through periods of being loud and then quiet.
Here are sum pics of my current loop:
The red arrow is the direction of flow. The blue arrow is where the the air bubble blockage occurs.
The issue:
