- Jun 24, 2014
- TX/CO
Ok so this might be an odd question, but I don't want to regret this potentially happening when I build my first custom loop.
I'm going to have, among other things, a dual bay reservoir, and a 360 rad in the top of my case, so the reservoir will not be the highest point in the case.
My question is - wait I should probably preface this by saying that the reservoir has the pump built in, and the pump outlet will be going straight over to the CPU, and then up to the top rad.
Anyway, upon filling the loop, once the loop is pretty full, once the pump stops, since there's water in the top rad, and the reservoir is not the top item in the loop, will the water above the reservoir start making it's way to the reservoir, overflowing it? Kinda like poking a hole in a water bottle - the water has a way to lower it's potential energy so it takes it. Is this going to happen with the loop? Will the water above the reservoir makes it's way to the reservoir, fill it up, and overflow it?
I'd rather not flood my system, and I've been ignoring physics in my loop consideration up until now. Haha
But plenty of people have top rads, so surely there's a solution if this is, in fact, a problem.
