The next question, is your pump rated to push the amount of water that 2 reservoirs will have? As long as your radiator is performing it's function properly, you shouldn't need anything more.
Sure can, as long as it's all gonna fit back in nicely.
I've used a single MCP 350 pushing 40' of 3/8" copper tubing, plus 12' of 1/4" tubing and still got just shy of a gallon per minute...strong little buggers they are.
