Hi all,
first off : Let me say this is my first post here and i consider myself a watercooling novice !
I have some concerns regarding the strength of my watercooling pump and whether or not i should upgrade/alter the configuration.
I am currently using the Raijintek Triton AIO CPU watercooling solution with a custom copper 240mm slim radiator, wich has been expanded to my GPU. I opted for this solution because i am using a Mini-ITX setup and have limited space for bigger reservoir/pump combo's. Having the reservoir, pump and block all in the same location right in the center of the case where space is plentifull is a positive.
The pump on the AIO cpu cooler supposedly has a 120 liters per hour capacity. With the current setup my temperatures on both CPU and GPU are acceptable.
But since i plan to upgrade my GPU to a more powerfull card with waterblock, and i also plan to overclock the system, i was considering of adding a secondary 240mm radiator to the loop. The space taken in by this radiator + fans is not really suited to house a reservoir+pump combo because it would have to be mounted horizontally which would cause problems. I can probably mount a small pump in the bottom of the case however, providing a good multifunctional mounting bracket is included. I have basic tools, but the case is mostly plastic and not verry suited for customization and pre-drilling holes.
To get to the point : Will the current pump be able to provide enough flow for a dual radiator setup + GPU and CPU block? Or is it recommended to switch to a pump with more capacity? Since its a compact Mini-ITX system there are a few 90 degree fittings to consider, but there is not much tubing obviously. Altough i would like a good flow, i also dont want any overkill for obvious reasons. I would switch off the pump on the AIO cooler and use it strictly as a reservoir/cpu cooler, while using a custom pump to provide flow.
Or : i stick to the AIO pump
Seeing as most popular pumps seem to have flow rates of anywhere between 200 to 400+ liters per hour, i assume that my current pump is underperforming? Will this performance affect my loop up to the point where temperatures are going to be highly affected by it? Or to the point where the pump might suffer damage? If so, than i would appreciate any pump suggestions that would be great for Mini-ITX form factor.
I have 2x120mm predrilled fan holes in the bottom of my case which are not being used, and can be utilized for mounting brackets or other mounting solutions, but again : space is limited as the psu, SSD bracket and a whole bunch of sleeved cable are already taking up most of it.
Thanks in advance.
Thanks in advance.
