I'll start with the system. I don't own it yet, but will be buying within the next 2-3 weeks.
Theme: Red and Black
CPU: Intel Core i7-2600K
Motherboard: Asus Maximus IV Extreme-Z Z68
Memory: 16 GB Corsair Vengeance DDR3 1866
Boot Drives: 2 x 120 GB Vertex 3 Max IOPS in Raid 0
Power Supply: Seasonic X-1250 Gold
Case: Xigmatek Elysium - Black
Media Drives: 2 x Asus DVD Burners, Asus Blu Ray Reader
I already own and will carry over:
Graphics Cards: 2 x EVGA GTX 570 SC's in SLI
Hard Drive: 1 TB Seagate 7200.12
Monitors: 3 x Samsung 23" @ 5760x1080
Sound Card: Sound Blaster X-Fi Fatality Champion Series
Keyboard: Logitech G19
Mouse: Logitech G9x
Gamepad: Logitech G13
Headphones: Logitech G930
Water Cooling System:
Pump: Swiftech MCP 35X
Resevoir: Swiftech MCP35X Rev 2
CPU Block: EK Supreme HF - Acetal
Radiator 1: Hardware Labs Black Ice GTX420 420mm Radiator
Radiator 2:
Option 1: Hardware Labs Black Ice GTX280 280mm Radiator - If it will fit. Does anyone know if it will fit? The Seasonic X-1250 is 7.46" long according to Neweg specs.
Option 2: XSPC RX240
Tubing: Tygon R-3400 1/2" ID 3/4" OD Black
Biocide: Silver Kill Coil
Liquid: Distilled Water
Fans: I need some help here. I figure I'll just go with Yate Loon fans, but I want them with red leds. I have red 230 mm fans that I'm going to take out of my HAF X and put in the Xigmatek where the 230mm fans are. Remember I'm going for a red on black look here. I figure where 120's go I'll go D12SM-12 red led, and for the 140s I'll go D14SM-12 red leds. Is this a good choice? Should I go for the highs rather than mediums? I'm planning on having a fan controller, which I'll discuss next.
Fan Controller: Lamptron Touch - This fan controller has 6 channels and supports up to 30w per channel. If I'm running push or pull only I'll have 3 140s and either 2 more 140s or 2 120s along with 3 120s for the case and a 230. In total:
140x5, 120x3, 230x1 or 140x3, 120x5, 230x1
Either way I'll be powering 9 fans, and 14 if I go push/pull, which I'm strongly considering. Will this fan controller handle that amount of fans, or will I need two?
Lastly, I want opinions on configuration of parts. Right now it's a cpu only loop, but it will I will add the gpu's when I upgrade to the GTX 600 series. I've came up with 2 options. Here they are:
Would I be able to fit a 280mm for radiator 2 in either confiuration? Which one do you guys think would be more feasible/effective?
Fittings: In the images you see a purple connector. This is a Koolance QDC VL3N joint. You'll also see in front of the case a purple connector on spare hose. I'll use this hose with another Koolance QDC on it to drain/flush the loop. I can just disconnect on the res inlet and connect the spare hose to drain in a bucket while I keep water flushing through the system.
You'll also notice 2 orange connectors on the CPU block. These represent 2 more Koolance QDC joints so I can split the system and also change any cpu/mobo without disassemling the system.
All other fittings will be Bitspower Ultimate G1/4 Compression Fitting 1/2" ID 3/4" OD.
That's my plan guys. I'll take any advice or suggestions. This is my first watercooling build, so anything that I should be aware of that I haven't outlined here such as angled fittings or any other little tricks I'd appreciate it.
I need suggestions on the fans, configuration, and whether I should push/pull on the fan configuration or not. Also, will one Lamptron Touch be enough? Where should I buy the Late Yoons? I've read that some places are better than others. Frozencpu is the only place I've found that has both 120 and 140 mm medium red fans.
Thanks so much for any input guys. That was long, but I think I'm done lol.
Edit: Is the EK Supreme HF still the best block on the market? I did the research to build this system back in April, so I don't know what's changed since then. Thanks guys.
Mouse: Logitech G9x
Radiator 2:
