This is my first watercooling build. It is silenced optimized. I have spent a few days researching parts and howto's, I am not by any means an expert so please critique. The parts I have chosen seem fairly cookie cutter and well used, but any suggestions or changes I would appreciate.
Current specs-
Asrock Z77 Professional
i5 3570K @3.4Ghz
Corsair H100 (this thing is a piece of garbage and I regret the purchase)
Corsair Vengeance 8GB
MSI 680
Seagate Barracuda 2TB
Intel 520 120GB
Corsair AX650
NZXT Switch 810
I am looking for a silence optimized machine. I will also add an NZXT Hue in the future for lighting.
Watercooling idea-
CPU Block- Swiftech Apogee HD
Reservoir – Swiftech MCRES Micro Rev2
Pump- Swiftech MCP 655
Rad 1- Black Ice GT Stealth 420
Rad 2 - Black Ice GT Stealth 280
Fittings - Bitspower Compression Fittings
GPU Block - Still not 100% sure on this one. I was looking at some from EK late last night and decided to ask someone who knew more than I did on this. A "standard" one besides the EVGA Hydrocopper (I have heard some bad things about EVGA waterblocks so I am reluctant to purchase one) does not seem to be found. Also, is it just me, or are more AMD waterblocks available for purchase than Nvidia ones?
Fans- Again, not decided. I am looking for ones that are silent. Temps are of little concern to me, anything beneath 60C or 70C is fine. I am pulling 38C on a H100 with stock fans so if the temps increase I will eat a shoe. If you know of some that are black with no LED's and silent I would love to know. This is much more difficult than I anticipated because so many come with LED's and the ones that don't seem to be UV reactive or not black.
EDIT: Also, forgot to mention, I would appreciate if they are 140mm fans.
EDIT2: I can't believe I forgot tubing. Originally, I was going to use distilled water + dye, but, after reading your Beginners Guide to Watercooling, I think I will use distilled water and colored tubing, possibly UV reactant. I will use PT Nuke as a biocide.
Current specs-
i5 3570K @3.4Ghz
MSI 680
Intel 520 120GB
Corsair AX650
NZXT Switch 810
Watercooling idea-
