- Mar 20, 2011
- Dublin, Ireland
Hi all,
I decided it probably better to start a new thread from my old one since I had changed the spec a good bit and changed components based on advice received.
So I'm hoping to get some more advice on what I've provisionally decided on below, please feel free to make comments and suggestions and I'll do my best to take it all in
Just to bare in mind, my aim is to have a medium between overclocking and noise reduction, so I will be overclocking slightly on the following
**I'm hoping to have the following done in one loop, I hope I can receive further advise on this as I'm using a high quality pump etc and only cooling 3 components
**Another thing I'd appreciate some piece of mind on is that I've selected the correct tubing/fitting sizes, I'm going for 1/2" (I'm a little mixed up between ID and OD?)
**Another question I have is regarding the fans, I am thinking about using two 360 rads (one for cpu and one for 2x GFX) and I was wondering is just attaching fans to one side of the rad acceptable?
What I'm going to be watercooling:
Intel i7 970 6 Core CPU
EVGA GTX 590 Hydro Edition
Watercooling equipment I'm going to use:
Laing D5 Vario Pump 12v 1/2" ID
EK-Supreme HF Full Copper Universal CPU Block
XSPC RX360 Black High Performance Radiator (x2)
Bitspower Matt Black Compression Fitting CC5 For ID 1/2" (x6)
Bitspower 1/4" BSPP - 1/2" ID - 3/4" OD Rotary 45 Degree Comp (x6)
XSPC Acrylic Dual 5.25” Reservoir for Laing D5
Scythe Gentle Typhoon 1850 RPM (x6 - 3 for each 360 rad in push config)
Masterkleer hose PVC 19/13mm (1/2" ID) UV White
EK-UNI RAD Holder (for attaching the other GFX rad outside the case - would this be suitable?)
Distilled water + PT nuke
Appreciate any help/advice
