Hello
I'm new to the forums and new to watercooling. The stickies are wonderful! Thanks for having such a great resource.
I'm going to be putting together a waterloop and I was wondering the best ordering would be. I noticed on the sticky it said ordering didn't matter since water temp would be the temp of the hottest component but I guess I've read in a few other places that order does matter so I was wondering if anyone had any suggestions on ordering.
I have 3 680s in SLI. With GPU waterblocks and vram heatsinks. Basically like this guy: http://www.evga.com/forums/tm.aspx?m=1658276. I already have GPUs so full cover waterblock not an option. Don't fit on my card.
For mobo: ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
CPU: 3930k and waterblock (haven't purchased waterblock, cpu or mobo yet)
I'd also like to get the chipset cooler for the mobo
Pump: probably the Swiftech MCP355 recommended in stickey
So for rads I need 120.5 right? I assume a 3 and a 2?
1) Any thoughts on best ordering of components?
pump-> cpu -> chipset -> 2 -> GPUs -> 3 -> res an ok setup?
2) Any thoughts on a power supply?
3) Any suggestions on a case?
Or any other comments would be greatly welcomed. I do a lot of multithreaded programming for my research and I also play with 3ds Max as a hobby so that's why I'm thinking 3930k. Also from what I've read IvyBridge E is going to be LGA 2011 so perhaps thats an upgrade option. I also do CUDA research so that's why I'm going with NVIDIA. So mostly it's a work computer but I do like to play games as well.
Thanks again
Brian
Thanks again
Brian
