- Oct 21, 2015
- Portugal , Setúbal.
Hello!!!
So i have a CM seidon 120V and i was thinking of modding it by adding a 240mm Rad and a Reservoir, but because iam new to this Watercooling world , i didnt realizei was making a mistake by placing the reservoir below the PUMP/cpu block.
that was the hole idea to use the CPU/pump from the close loop i have, and mod it.
iam here cause i need help and an opinion from you guys.
this is like it was:.
this is like it was befor someone poited me the fact that i had the Pump/cpu block above the reservoir :.
and this is how i thinking to place it to minimize the problem:.
Ive took the reservoir out of that place to see if i had remotly a way of placing the reservoir above the pump/cpu block and the best i can do is this and it will preaty much be at the same lvl as the intake of the pump but cant place it higher, and to place it like it is i will have to fill the reservoir out of place and then place it in that possition as the picture below , whit the filling place completly inside and aganist the top of the case.
i could also get rid of the Purge valve and and try to place the reservoir horizotntly at the right of thr MEM´s .
any sugestions ?
Thanks in advance.
Pulsarius.
any sugestions ?
Thanks in advance.
Pulsarius.
