- Feb 14, 2008
- Chicago, IL
My System Specs:
eVGA NForce 680i SLI Motherboard
Intel QX6700 (OC'd to 3.2GHz) w/ 4GB RAM
Dual Nvidia GeForce 8800GTXs
Case: Alienware 7500 full tower 2.0b chassis
Parts I'm planning to buy from DangerDen:
Thermochill PA120.3
DD12V-D5 Pump Variable Speed
DD - 8800 GTX water block (2x)
Yate Loon High Speed Fan: D12SH-12 (6x)
Thermochill Neoprene Gaskets (2x)
Tygon 3603 Tubing 1/2" ID 3/4" OD (approx. 10-15 feet)
MCT-40 Non-Conductive Solution (1-2x?)
Plastic Snap Tubing Clamps (14x - should I get extra?)
Polypropylene "T"
Danger Den Fillport
My situation:
I have two routes to go.
#1: Keep the current cooling system for the CPU. Drill two 1" holes in the back of the case (possibly difficult) for tubing to/from an external radiator.
#2: Use the PA120.3 for the CPU & both GPUs. This would make my life easier since the existing radiator would leave a nice gap behind in the back so I don't have to drill holes.
My decision between the two is based on two questions:
1a) Can the PA120.3 handle the load from the CPU & GPUs efficiently?
1b) Would the proper loop setup be: Rad -> Pump -> CPU -> GPUs -> Rad?
1c) Where should the t-line be? Before the rad/pump? After?
2a) How easy is it to remove the existing CPU water block & replace it? Anything in particular I should pay attention to during the process? (Should I replace the thermal grease with fresh stuff? Any special way to do that or just wipe it up?)
2b) Would this be the right water block for the CPU? MC-TDX for Intel 775 CPU/Boards
2c) If so, I noticed I have two choices for "Top Style" between Lucite & Brass. What's the difference? Are there advantages/disadvantages of one over the other?
Second thing I'm concerned about is powering new pump/fans. If I take out the existing cooling system, that should open up a 4-pin connector from the pump that's already installed. Can I safely daisy-chain the 6 new fans & pump into that one connector? Is that an overload on the one plug or just the PSU in general with all the other stuff I already have on there?
(Side note: When heavily gaming, perhaps CoD4 or something, after a while my comp might either restart or shutdown, which I'm assuming is due to overheating. I assume that because if I open my big window with this Chicago winter going on, it never happens. I talked to Alienware tech support, and the guy said the shutdown threshold on the GPUs is around 120C & the motherboard was around 100C [i think he said 100C for that, it was late last night...hard to remember] I kept everest open & ALT-TABed out after a while. My GPUs never get more than 80-82C & I've never seen the motherboard get hotter than 60C, which was from running Folding@Home after 24 hours, not from gaming. I'm only left to believe it was the PSU overheating perhaps. I think it's plausible since the GPUs get so hot...the heat could rise & further heat the PSU, which would stop when I liquid cool the GPUs. However, the tech guy said the PSU overheating with my setup isn't very likely so I dunno. *End side note)
If I don't take out the current cooling system, I wouldn't have any open connectors & would probably have to get a second PSU for the pump/fans, right? If so, could I just have it power the pump/fans with this adapter without having a motherboard to plug it into? If so, I think I'll get this PSU.
I plan to get 10-15 feet of tubing (I know I won't be using this much, but extra never hurts), what's the max tubing length in a setup that the DD12V-D5 pump can handle to keep up the proper flow? Will I be okay for what I plan to do?
For the fillport, do I have to have it through a hole drilled into the case? Or can I leave it connected to the t-line without doing so?
Where can I buy deionized water to leak test? Or can I use distilled?
How much coolant will I need? 1 bottle (32oz)? 2?
How long should I leak test for? (I've read varying times online from about 1-2 hours through 24 hours...)
What kind of maintenance should I expect with a liquid cooling system? Do I need to replace the coolant every so often?
Anything I'm forgetting to buy?
Any aspect of this entire process I'm overlooking?
Thank you very much in advance for your responses; they will all be greatly appreciated
Thermochill PA120.3
Polypropylene "T"
Danger Den Fillport
My situation:
