- Thread Starter
- #21
I have found that the best all around size is the 120mm-140mm for the tube. Once you have the loop filled with coolant, what is in the tank is Extra..... Like a full bottle ($15-$20) just sitting there. I have seen on some sites where coolant left in tank has left perminate visible rings on the tube. Make sure you check the coolant =compatibility= with your parts. The BIGGEST thing to remember, drain and re-fill/re-hose new EVERY 6 Months. This will keep your blocks looking and preforming at there best I have had and still use 4+ 90's that are over 5 yrs old.
I have this model http://www.performance-pcs.com/ek-xres-140-revo-d5-pwm-incl-sleeving-and-pump.html and also HIGHLY recommend the D5/MCP-655 Pump (Same just different maker = 6 total) http://www.performance-pcs.com/pump...5--laing-d5-pwm/?dir=asc&limit=90&order=price
In the end, I gave up on paying $$$ for coolant and just run Distilled Water (1Gal=$1.50/4L=$1.75 USD).
Thank You For Your Time
Hi, i will buy this res/pump combo https://www.ekwb.com/shop/ek-xres-100-revo-d5-pwm-incl-pump and then upgrade the tube to this https://www.ekwb.com/shop/ek-res-x3-tube-250-204mm or this https://www.ekwb.com/shop/ek-res-x3-tube-400-354mm ahah
