- May 4, 2011
So, my two fans installed at the top of my case oscillate the dust panel noticeably louder than the fans themselves when they are both set to the lowest speed. A workaround is to raise their speed, setting one about midway between full power and low power, and the other around 25%.
I do know that weighing the panel down stops the noise( the culprit is the plastic/mesh cover on the air 540) but I wanted to see if anyone else had any suggestions they might add, like tightening or loosening the thumb screws that hold it in place, Or some other method.
I keep the fans at minimum unless I'm gaming on a graphic intensive game, which I kick them to full, My G930 canceling out most of their noise, and the game sounds drowning out the rest.
Rubber mounts are not currently an option, but I am planning to switch to them if this problem persists.
