- Oct 25, 2004
- Ontario, Canada
OCZ Dual Channel Platinum Rev. 2 TCCD 2-2-2-5
DFI LanPartyUT Nf4 Ultra-D
AMD Athlon64 3200+
OCZ PowerStream 520W
Hi guys. Now I have tested all stock settings/timings, they work just fine. However, I have discovered that my memory will only boot with CAS 2 latency.
What I did was, loaded optimized defaults in the bios, set the memory timings and booted. No problems. Then I left one stick in, left at 2-2-2-5, booted no problem. I restarted and set to 2.5-2-2-5, and before Windows starts loading it will either hang or immediately give me a BSOD. This occurs with either or both sticks trying to run CAS 2.5 or 3.
I have tried Memtest86 with 2.5-3-3-7 250MHz, no errors at all (both sticks).
I just don't understand where the problem could lie. If the memory were faulty, would it not give errors in Memtest86? Any help would be appreciated.
AMD Athlon64 3200+
