Are three bladed fans also quieter for the CFM they deliver vs. 7 or 9 bladed fans?
So, basically 3-bladed fans make good exhaust or intake fans, but aren't good for
heatsinks or radiators?
Typically they're a bit quieter, but also typically they're high RPM, so it doesn't really matter from a practical perspective.
So what's the point of manufacturing them at all? Do they at least use less power for a given CFM than a 7-blade or 9-blade fan?
AC motors (driven direct off the mains) have a lower maximum power density than BLDC motors since an AC motor is limited to 3600 RPM at 60Hz. What the HVAC industry calls an ECM motor is actually a high voltage BLDC motor.
You'll find that 3 and 4 blade fans are very common in HVAC condensing units and ductless indoor units.
