Hi!
One of my friends is having problem at playing Counter-Strike Source game. He usually had constant 250 FPS before. Nowadays (~1 month), he is having 150-200 FPS and about 10 seconds it falls under 100, sometimes 50 (so that makes huge lags for him). He has tested the temperature of his graphic card, but it is/was normal.
Some days ago, he ran a test with 3dmark and everything was ok, but CPU test. As you can read lower, he has 3.10 GHz, but the test result showed him 0.765 for CPU clock. May this could be the source of the problem?
Also, he has a pretty old (5 years) hard disk and (a) CRT monitor, that could make some trouble.
By the way, he has reinstalled his PC, but it didnt change anything, so its probably a hardware problem. He has been thinking about purchasing new hardwers, but we are not sure about the problems.
He has the following configuration:
Motherboard - GIGABYTE GA-M68M-S2P
CPU - AMD Phenom II 550 3.10 GHz
RAM - KINGSTON 2GB 800 MHz
Graphic card - NVIDIA GeForce 9600 GT 512 MB
Monitor - IIYAMA Vision Master Pro 451
General resolution - 1024*768 @ 140hz
OS - Microsoft Windows 7
Hard disk - Seagate Barracuda 7200.7 80GB (bought about 5 years ago)
I hope someone could help us and solve this problem!
