Ok i was thinking of this the other day while looking at the info section on water cooling.I was looking at a review and they were saying that the more surface the better and they were comparing a copper block and a block made from an aluminium hs both were the same so i decided that i would get the hedgehog(476m for slot a copper)amd solder some sides on it and use it to cool down my classic athlon 850@1074(124fsb)ram at 169 cas 3) and then i started thinking a bit more and thought that while i was at it i should put some tec(peltiers) on there tooand decided that i would make my plates that i would solder on it a little longer and meke them go down a bit under the hs(hope your still following me here i know it aint too clear but im doing the best i can)and make an incasement for some peltier instead of using another cold plates and was thinking of three peltier 80 watts each or maybe 3 118 watts uncertain at this point.Do you guys think this is a good isea and do you think that maybe i could double up my peltiers and the hs would be able to handle the heat with water at 20C and cpu pushing sarround 100watts of heat.And for stacking up peltiers maibe 6 72 watts any tips or info on this would be greatly appreciated . cause im pretty knew at thic thanx
Buffhr
here is a pic of the heatsink
Buffhr
