- Aug 8, 2016
So here's the deal I have a HTPC that isn't getting anywhere near what it should on my network. It's about 20ft from the cable modem/router and hitting 65mbps on a 400mbps line. My MacBook Pro sitting in the same spot and doing a speed test to the same server gets 320mbps. So there's obviously an issue with the HTPC. The HTPC has an ASRock mini-itx board that came with it's own wifi that's an Intel Dual Band Wireless-AC 3160. I've updated the bios and all drivers through ASRock for everything.
I'm using NetSpot software and seeing the signal strength isn't the best on the 5ghz scale. I don't really get why since it isn't that far and there's no walls or anything in the way. Anyway I'm on a 400mbit plan with Comcast and currently using the ARRIS SBG6900-AC which says it's AC1900, DOCsis 3.0 with speeds up to 686 mbps.
I really can't figure out why the 2017 MacBook Pro hits 320mbps in the same location as the desktop getting 65mbps running a speed test to the same server. My iPhone X was basically right there around the desktop.
So how does it exactly work does a stronger router make a better difference or do I need to get a USB-AC wifi card that's pretty monster and keep the current router? Also I have a spare Linksys EA6350 that's a couple years old but it's a wireless AC1200+ Router. If there's some way to connect the HTPC to that with ethernet and use the router as a antenna for the HTPC would that be the best setup or would it cut the networking in half?
