- Nov 26, 2004
- AB, Canada
I've always done it on occasion just to... maintain my monitor. I never really knew what it does though. Any ideas?
cack01 said:If you want to see how it works, turn your monitor on its side and turn it on. Since different magnetic fields will be hitting the CRT in different locations, there is a good chance your monitor's picture is going to be completly messed up. If you then Degauss the monitor, you will begin to see a better and better picture each time you do it, untill the monitor is calibrated ffor the new magnetic field. You will also need to Degauss if you move across the globe, since you will now be in a different magnetic field.
Jtanczos said:How about you do it and take pics for us
Interesting info but I sure dont want to test it out.
JT
theELVISCERATOR said:demagnetize....you can degauss anything magnetic with a 60hz AC field.
larva said:Degaussing is not an iterative process. If you need to do it, you only need to do it once.
Also, there is a bit more of a need to degauss than you imply. Most modern computer monitors will degauss every time they power up.
