- Oct 10, 2002
- Dallas, TX
What have I got wrong? - High temps
First off, here's my system -
P4 2.4B (B0 Stepping)
512Mb Corsair XMS3500 CAS2
Abit IT7-MAX2 Rev2 (PE Chipset)
Gainward GF4 Ti4200 Golden Sample
Maxtor 80Gb D740X (via Serillel adapter)
Enermax 431w PSU
Here's my cooling setup -
OCPC Atlantis CPU, NB and GPU Waterblocks
OCPC "The Deep Rev2" Radiator
120mm YS-Tech 125CFM Fan
Eheim 1250 Pump
1/2" ID Silicone tubing throughout.
3 x Adda 80mm Case Fans
The Radiator is mounted at the front of my case in place of the 2 fans which came fitted in the case (below the 3.5" Rack), with the 120mm YS-Tech on 7V attached to the back, pulling air through it.
I have one of the 80mm fans in the top of my case blowing air out. The other 2 are "stacked" together at the back blowing air out. These are all on 12V.
The adjustable fan on the PSU is at full power.
The watercooling setup goes Pump -> T-Line -> Rad -> CPU -> GPU -> NB - > Pump.
The blocks have all been lapped to 1500 Grit and mounted using AS3
With this setup, I am getting these temps (all measured through the Winbond Hardware Doctor provided by Abit) -
133 FSB and 1.5V BIOS Vcore -
Idle System = 30*C
Idle CPU = 42.5*C
Idle Vcore = 1.44V
Load System = 32*C
Load CPU = 47*C
Load Vcore =1.44V
167 FSB and 1.85V Bios Vcore -
Idle System = 31*C
Idle CPU = 48.5*C
Idle Vcore = 1.79
Load System = 34*C
Load CPU = 58*C
Load Vcore =1.76
Ambient Temp is 21*C
Do these seem high to anyone else or is it just me??
On top of this, my GF4 won't overclock at all now and occasionally crashes at Stock Speeds in 3DMark (It used to do 330/610!!)
Thanks
Chez
Enermax 431w PSU
Eheim 1250 Pump
Idle System = 30*C
Idle CPU = 42.5*C
Idle Vcore = 1.44V
Load System = 32*C
Load CPU = 47*C
Load Vcore =1.44V
Idle System = 31*C
Idle CPU = 48.5*C
Idle Vcore = 1.79
Load System = 34*C
Load CPU = 58*C
Load Vcore =1.76
Thanks
Chez
