I've run 14 soldered de-lidded AMD processors naked. Lots of athlons and semprons from s462 to AM3.
Knowing this is not related directly to de-lidding of Intel processors, from what I do know, AMD is easier to deal with. I was enlightened recently that Intel chips have much less surface area and seem to be fragile if too much pressure is applied. And typically with de-lidded processors, you need a decent amount of clamping force. So the Cpu PCB and or motherboard PCB can bend, which I've seen cause no post issues with my higher TDP AMD processors.
The nice thing about removing layers of copper and thermal paste is you have a much faster transfer of temperature from Cpu core to waterblock. However it seems to have the biggest impact running a much higher TDP than most people would do. I found in most cases an average of about 10c can be lost with running naked. My FX-5000 didn't seem to make much difference as it didn't clock well having the TLB errata issues only reached 2750mhz unlocked. could have done that on an air cooler really.....
I do have a 2700X that some time in the future (no actual deadline set) to de-lid. For now I'm still getting used to the processor and currently running the stock air cooler and heavily limited by temperature near the 1.5v area which I need to surpass the 4.4ghz barrier I'm at now. But then again, it's plenty fast, I run it daily at 4.2ghz typically and leave the voltage on auto believe it or not....
Any Hoot, here's that soldered AMD naked list I've accumulated through the years, just in case some one thinks I've not been down that naked road once or twice. (Have done a couple of Intel chips also
Here's 14 working cpus and I did Kill 2 so 16 total. Cannot give a direct number on non-soldered processor, we'll say maybe a few dozen or so?
FX-4300
FX-6100
FX-9590
FX-8320
B73 x3
Athon 5000+ unlocker FX-5000
970T
1090T
965BE
940BE
9850BE
9950BE
6400+ x2
