- Oct 11, 2012
To start off, I recently purchased the XSPC rs240 kit. I've been reading that this rs240 radiator is a "budget" series in all aspects.
For now, it will be used to cool just my processor (i7 3930). My goal is to reach a stable overclock of around 4.5 - 5 ghz...most likely closer to 4.5.
The question is...will the rs240 be sufficient for my goals? Or...would I see any noticeable gains with an upgraded rad. I will be running 2 delta tfc1212de fans in push config fyi, which is probably over kill...plan is to turn up the fans when I am rendering or doing heavy multi-tasking between autodesk and adobe programs.
Anyways, I have narrowed down my selection to 3 radiators:
XSPC RX240
http://www.performance-pcs.com/cata...t_info&cPath=59_457_667_671&products_id=25388
XSPC AX240
http://www.performance-pcs.com/cata...t_info&cPath=59_457_667_671&products_id=36038
Alphacool Nexxos ut60 240mm
http://www.performance-pcs.com/cata..._info&cPath=59_457_667_1075&products_id=32769
Any other suggestions welcome...what do you guys think? From what I have been reading, the Nexxos ut60 performs well with decent gains from low to high rpm fans. Haven't seen too many tests or benchmarks on the new AX series from XSPC.
XSPC RX240
XSPC AX240
