I want a waterblock for my loop.Does flow rate of the waterblocks matter?i will be using 3/8 inch id 5/8 inch od tubing and 2 480mm radiators and a gpu block and a phobya balancer 250 reservoir and an mcp655 pump.
The lower flow block:
http://www.performance-pcs.com/cata..._info&cPath=59_971_498_1176&products_id=36091
The Higher flow block:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=36055
Which one should i buy? the phobya block has a low flow rate of 146 and the koolance 380i has a higher flow rate of 181 so which one should i buy?
Thanks
Thanks
