- Sep 26, 2013
- United States
All,
I'm beginning my adventure into water cooling. My system is as follows:
Corsair 900d
ASUS Maximus V Extreme LGA 1155 Mobo
Intel i7 3770k CPU
16 gigs Corsair Vengeance RAM
2x EVGA GTX670 video cards
Corsair AX860i PSU
Crucial C300 120GB SSD
Seagate Barracuda 2TB 7200 RPM Drive
DVD R/RW Optical Drive
The case came stock with the following fans that I will be utilizing for the time being:
3x Corsair AF120 fans for intake on the front
1x Corsair AF140 fan for exhaust on the back
I'm looking at purchasing the following for cooling:
Swiftech MCP655 Special Edition 12 VDC Pump With Speed Controller -
http://www.performance-pcs.com/cata...e=product_info&cPath=59_201&products_id=33677
XSPC EX360 Copper Triple-Fan Radiator -
http://www.performance-pcs.com/cata...t_info&cPath=59_457_667_671&products_id=32460
XSPC RayStorm CPU WaterBlock for Intel Sockets (Intel) -
http://www.sidewindercomputers.com/racpuwai.html
EK-RES X3 250 Reservoir -
http://www.performance-pcs.com/cata...oduct_info&cPath=59_318_659&products_id=35998
Durelene PVC tubing 3/8in. ID 1/2in. OD by Saint-Gobain -
http://www.sidewindercomputers.com/dupvctu3id1o.html
EK-PSC Fitting 12mm - G1/4 Black - Compression -
http://www.performance-pcs.com/cata...oduct_info&cPath=59_346_365&products_id=27336
EK-PSC Adapter 45° G1/4 Black (To help make the bend from the radiator to the CPU and another for the bend at the bottom of the res to the CPU) -
http://www.performance-pcs.com/cata...oduct_info&cPath=59_346_365&products_id=34423
Koolance QD3 Quick Disconnect No-Spill Coupling, Male Compression 10 x 16mm (3/8 x 5/8in) Black X2 -
http://www.performance-pcs.com/cata...t_info&cPath=59_346_203_481&products_id=38129
Koolance QD3 Quick Disconnect No-Spill Coupling, Female Compression 10 x 16mm (3/8 x 5/8in) Black X2 -
http://www.performance-pcs.com/cata...t_info&cPath=59_346_203_481&products_id=38127
Corsair Air Series SP120 Quiet Edition High Static Pressure 120mm Fan X3 -
http://www.performance-pcs.com/cata..._info&cPath=36_1130_49_1156&products_id=34316
OK, now that the parts list is laid out, my plan is as follows:
1. The loop will only cool my CPU for the time being. When I add in the video cards, an additional 480mm rad will be added as well.
2. I plan to install the 360mm rad at the top of the case with the inlet/outlet close to the 5.25" bay
3. I will connect a 45 to the out of the rad and run tubing to the CPU block.
4. I will then run tubing from the CPU block to the a 45 connected to the Res.
5. Tubing will run out of the bottom of the Res to the pump which will be installed in the bottom of the case
6. Tubing will run from the pump up the backside (hidden) of the case to the inlet of the rad
7. Close to the pump on the tubing that runs between the pump and the rad i will install the QDC's for draining.
8. The 3 Corsair SP120 fans will be installed on the rad at the top of the case, I'm not sure if these should be sandwiched between the rad and the case or if they should sandwich the rad between themselves and the case top. I'm also unsure about whether they should pull air into the case or exhaust air out.
This is my first foray into water cooling so any feed back, do's, don't's, pearls of wisdom, or advice would be GREATLY appreciated.
Thanks everyone!
Corsair 900d
Intel i7 3770k CPU
Corsair AX860i PSU
Thanks everyone!
