- Jul 20, 2002
My new fav fan delta 252cfm at 5000rpm pwm. I am running 3 of these bad boys and I like it. I used 2 of them for the heatsink Noctua NH-D14 and 1 for exhaust. I have plan to add 1 more for air instake, place under the blu ray player (NZXT full tower) but I will have to made a bracket for it. I set the fan speed at 2400rpm at idling, as cpu get hotter, so the fan rpm get higher. you can not hear the fan noise from 12 feets away at idling speed.. Note... if you get the NONE PWM version, it will be crazy loud. My cpu is 3930K overclocked at 4.6Ghz never get pass 71c in prime95. before the Delta fan upgrade, the cpu temp would hit 85C+ 91c in prime95. It so hot the cpu throttling down. Now it never throtttling down in prime95.
Do you need to file an FAA approved flight plan before you start up your
system?
