- Mar 1, 2013
With a good sized radiator, there won't need to be much back pressure to get enough flow. And you'll try to use the existing vents for the radiator and fans if possible.
I have two 3000 RPM 120mm Deltas in my hybrid air conditioner/water heater project and they don't need to run anywhere near max speed in order to get the correct airflow even though the compressor is rated for 5000BTU/hr, which is about 1500W. In fact, I could have got away with one fan for airflow alone, though having two allows me to play tricks like speeding up the bottom fan and slowing down the top one to back some liquid refrigerant into the condenser and increase the subcooling.
