- Aug 27, 2005
Isopropyl alcohol cannot melt acrylic sheet. I've searched google for the last 2 hours and found nothing of the sort.
According to the maker of Optix brand acrylic (common brand found at Home Depot) it can embrittle the plastic lowering it's crazing stress point to 900 psi (no parking cars on your reservior) but it won't melt it.
Acetone will melt plastics. We used to use iso alcohol to clean acrylic and acetone for glass housing windows. When the operator got the two mixed up, there went a $80 housing...
Straight iso alcohol can attack the glue joints, causing a spider-web of lines that look like cracks, but this does not happen when it's mixed with water because of the weird way alcohol molecules blend into water.
I wouldn't go swabbing high stress points like NPT threaded holes with pure iso alcohol, but what little is found in a few drops of iodine is so patheticaly small when mixed with your other coolant.
