- Feb 4, 2009
- cypress, tx
I am updating my water cooling and thinking about swapping the radiator. I currently have a Swiftech MCR240QP, but I could fit a thick radiator in the location of this one and in theory drop temps/lower fan speed under load. The build is white and black and I wouldn't mind keeping the theme and run a white radiator. So far I am looking at a couple hwlabs units, but can't decide if it's even worth swapping the radiator out to begin with.
The couple of rads I have seen (and I am open to suggestions regardless of color)
http://www.performance-pcs.com/blac...e-xtreme-profile-radiator-white.html#Features
http://www.performance-pcs.com/hard...port-satin-white-radiator-240mm.html#Features
Also quick note I am using a pair of 3 blade Delta PWM fans that run at 700RPM idle and 1500-2000RPM when the CPU warms up.
