- Jun 15, 2011
I just received my two 360 SR2 multiport radiators for my planned build. I'm planning to use both in a Lian Li O11 Dynamic case, so I know it's going to be a tight fit (but should work). The HWlabs webpage lists this radiator to 60mm full thickness. However, I was a bit disappointed when I opened up the box today. The stop-plugs protrude further than the official dimensions, making the radiator thickness 63mm (when the plugs are used on one side). Furthermore, it is impossible to mount the radiator level without using spacers because of the protruding stop plugs on one end of the rad. I know 3mm is not much in absolute terms, but there isn't much room between the bottom radiator/fans and the GPU, and I'd like to have as much space as possible.
Do stop plugs that can fit in a G1/4 thread without protruding exist? Apart from welding these ports shut or mounting not-protruding stop-plugs, I can't see any other way than using spacers. Intuitively, it seems like bad design.
