760 and 280 are almost neck and neck. Go for the Intel build. You can even cut to an i5 4460 and an H81 board. Go Intel. Blue team. FTW.
Yeah, but the 280X does outperform the GTX 760 even if not by a lot. And for a difference of $5 why not get the faster one? OCNoob, that's along the lines of what you yourself have generally advised in a number of other posts when you give advice for spending other's money.
280x and gtx 760 are not 5$ apart in the UK. The well regarded Windforce gtx 760 can be had for around 40 pounds cheaper than the cheapest XFX 280x, thats 62$.
Regardless, 280X is better than 760 by a small but significant margin. Is it worth the price difference? At $62 I'd have to say no. But that's up to the OP.
Sad that he wasn't in the USA on Black Friday. 290s were $199.
I like the first one because of intel prcessor and cheaper GPU, which is usually has only 2fps less than r9 280, but $30cheaper+gigabite gtx760 supposed to be very good. I personally got MSI.
I doubt that nvidia card is only 2 fps less then a 280.....
Id say go for 2nd setup.
Agreed. Used GPUs are usually a pretty safe bet. Ask the seller if the voltage has ever been pushed really high first though. You don't want that. You want a virgin card.
Ebay, kijiji, redflagdeals are good places to find a used GPU.
The setup with the wrong board, wrong RAM you mean? The one that'll underperform the first one in gaming? That one?
