- Feb 28, 2008
what upgrade should i do from P5BD and 6400?
Hello this is my first post and i done abit of research but i still got questions and love some advice. I own a Asus P5B Deluxe with 965 chipset and a 6400 Conroe with 4x1Gb Corsair DDR2 667 taking up all 4 slots that i had since 2006. I was heavily into overclocking upto 2007 but a so called long time friend(****) betrayed me so my heart wasn't into it anymore. I now like to upgrade again. I now see the P35, X38, 45mm has passed me by during that time and the X48 is due out next month not to mention the Nehalem which i don't think be out end of year but next year. I am wanting to upgrade to a quad core as i play chess alot but am unsure what to do. I know i want Nehalem when it arrives and don't want to shell out a fortune now but i like some decent performance increase. I know it make good sense to wait for X48 as the X38 should drop. I want to keep cost down if i can but want a decent performance % increase. I don't think i need to buy DDR3 right now as it far too expensive vs. performance. I'm in the Uk so i quoting £ not $. Just double it to get $.
Can i fit a 45mm in my Asus 965 P5BD as it still says 775 socket? I got a feeling i can't.
Can i flash my bios of my P5BD to make it 1333FSB?
If i can't do the above What should i do? Should I...
Buy a Q6600 65mm quad core to fit my existing m/b? £147
http://www.scan.co.uk/Products...sp?WebProductID=702631
Buy a 45mm Q9450 and a motherboard to match? £218 for chip alone.
http://www.scan.co.uk/Products...sp?WebProductID=743028
What m/b chipset should i get?
I seen X38 m/b is too expensive and scan only list 3 is there so few out for X38?
http://www.scan.co.uk/Products...tegories=235&OrderBy=3
I heard great things mentioned about a certain Gigabyte P35. As i understand it the X48 is the chipset the X38 should of been and only slight improvements. They overclock about the same.
What is confusing will the X48 take DDR2? I read 2 different answers.
It will won't take DDR3 as the Asus P5E3 Anandtech article mentions just DDR3 and the end of DDR2. http://www.anandtech.com/mb/showdoc.aspx?i=3229
It will take DDR2 but only 2 slots can be used.
So whats the crack?
I am thinking buy the Q9450 and a cheap motherboard and use my existing 4x1gb DDR2 Ram to get good performance and not have expense of a top range motherboard. If you think this is the best idea what motherboard should i get? Now i'm reading the X38 isn't much better over the P35 and only needed if you use crossfire which i won't be. You think i should get a P35 for now? I need Raid btw.
What i like to see is some performance differences of my 965 chipset over the 45mm quad core.
What i really like to know is there much performance difference between 65mm Q6600 and 45mm Q9450 to be worth the expense of buying a new motherboard for it.
Sorry for all the questions. I been out of it and getting upto speed.
Many Thanks and great site and forum.
So whats the crack?
