Hello all,
First off I will give you all a bit of back ground about me. I have been building computers for about 18 years on and off and I want to step up my game a bit. With this in mind the loop cooling looks like a fun and challenging project. I have read a lot about how to do it and what parts I need and so on. I have a pretty good understanding about that. But even with that information I still have a question for you all.
So my purpose for the build I'm doing is to be able to OC my CPU and GPU. I have read about relidding and it seems like a fairly easy process to do it you have the right tools. With this in mind I need some help figuring out weather I need need more than just one loop or two.
My system will be built as followed (hopefully this will help out)
CPU: Intel I7 8086K 4 GHZ
GPU: MSI The Duke 1070TI
Mobo: Asus Max Code X
Hard drive: 970 Samsung EVO SSD 500GB
Hard drive: 1 TB Western Digital Blue 7200
RAM: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3000 Memory
Case: Thermaltake - Core X71 Tempered Glass Edition ATX Full Tower Case
Power supply: Corsair - HX Platinum 850 W 80+ Platinum Certified Fully-Modular ATX Power Supply
I plan on OC clocking the CPU to 5GHZ as this seems to be a very stable speed and voltage for it. The GPU I'm going to have to play with a bit because most of the stuff I have read and seen is using stock cooling.
Hopefully this is enough information to let you guys try to make a good recommendation. Thanks again and I will forward to the responses.
