- Oct 10, 2012
- Secret lair
Ok I was kinda able to put the GPU in the bottom x16 slot however while doing my wrap up check I noticed the wires for the system panel connector was inside the fan well which means had I closed up and turned it on it would have cut the wires. Having seen it I simply put the card in the top x16 slot for now. So I will have to get a PCI-riser next month. Whats the cheapest protected riser I could conceivably get?
*Crosses fingers* Please tell me I can get a suitable one for around $50.... *Crosses fingers*
So for right now I took out the extra hard drive carriages and moved my three HDDs to the bottom three slots this way the top of the front intake fan will have a clear line of fire to the GPU the air stream doesn't quite hit the card but the intake fans will definitely pick it up that plus the side intake fan it's gonna have to do. I also plan on getting a 2nd top exhaust fan for the case I don't know if the 2nd exhaust fan will help but I might as well. Though the riser will have to take priority first.
Also since the system panel connector is the one thing preventing me from being able to comfortably seat the GPU into the bottom x16 slot would it be cheaper and easier to get a slim profile extender for it that way I can plug it in away from the actual board and then get enough clearance? The connector looks like a standard connector that smaller black connectors plug into from the top. One is for the system speaker, reset button, power on button, etc. So I actually need it if those black connectors didn't have to plug in from the top then maybe.... If I could just shave off maybe a few more cm I could do it easily.
There might be angled connectors around somewhere... not sure if NZXT did them. Search the electronics sites .. Mauser is a good a place as any to start (also for 3M PCIE risers). Otherwise you have to jury rig something yourself using "universal" angled connectors.
