JoshSucksAtCPUs
- Nov 5, 2016
I'm trying to overclock my FX 6300 to 4.2ghz, but Im having a weird issue. For some reason, my clock keeps dropping by 100mhz. Even though there is a fluctuation in the clock speeds, I'm passing prime95 tests no problem. Usually, when there's a problem it spits me out an error within 10-15 minutes. But, I can do tests for 4 hours+ and pass no problem with this fluctuation.
I have all power saving stuff in the bios disabled. I have HPC enabled. Windows power option is set to high-performance. Minimum processor state set to 100%.
I don't believe it's thermal throttling. Socket hits 64c during extended prime95 tests and package hits 54c. From what I've read, there's still room before throttling starts happening?
Im following a Pile driver guide I found on another forum. When it came to voltage it suggested "Back in the BIOS, scroll to CPU Manual Voltage and Manually Set it to whatever value it shows for your CPU". The baseline voltage for my CPU was 1.188 in the bios. IIRC, I was able to pass prime95 tests with 1.19 until I went to 4.1ghz. That's when I started to have to increase voltage. Right now, I'm somewhere around 1.28 in the bios but even though I keep stepping up the voltage the problem is not alleviated.
Anyone got some advice on this? What exactly is going on? Is it just a weak core that's like: "Nah bro it aint happening" or what?
Specs:
Windows 10
FX 6300
M5A99FX Pro R2.0
GTX 770
Corsair Vengeance 8GB 1866 @ stock XMP profile
Antec 650W Gold-rated.
Also, I'd post screenshots of HWMonitor and CPU-Z, but Im not sure if Im allowed to do that as a new member of this forum?
Specs:
Windows 10
FX 6300
M5A99FX Pro R2.0
GTX 770
