Where? I don't see it anywhere in the nVidia panel. I tried Forceware 56, 53, and 61 no temp monitorDONTSLEEP said:IN the driver panel theres a Gpu monitor already there.
Ah, thats not necessarily true. All Nvidia cards have thermal throttling ability, its built into all the GPUs. But not all cards can display temps from the GPU even though it can read them. I know my card has Thermal Throttling yet cant display temps.blurry said:Obviously if i doesn't have hardware temp monitoring, then it won't have throttling. That's how the throttling works. It checks the temps and throttles back to keep it cool and at a safe temperature.
How do you know your card has thermal throttling when you can't even change the settings? That's the indication that your card has no thermal throttling. BTW, not all Nvidia cards have thermal throttling ability.fac_29 said:Ah, thats not necessarily true. All Nvidia cards have thermal throttling ability, its built into all the GPUs. But not all cards can display temps from the GPU even though it can read them. I know my card has Thermal Throttling yet cant display temps.
The same goes with Motherboards and CPU's, some can read and display temps from the CPU diode yet some some cant. Yet ALL can(and have too..) read temps from the diode for CPU Overheat Protection.
blurry said:How do you know your card has thermal throttling when you can't even change the settings? That's the indication that your card has no thermal throttling. BTW, not all Nvidia cards have thermal throttling ability.
DONTSLEEP
No,Gpu throttling is in the core technology and all 5600ultra and higher Nvidia cards have it built in.
