- Feb 9, 2002
- Pensacola, FL
mattyhayden said:I turned sideband & Fastwrite's off. This has fixed the problem,
Will give it a good workout when I get home from work and try and sort it..
Switched back to 1.8 bios. Problem solved.
Sniper.nkc said:Switched back to 1.8 bios. Problem solved.
I have NV/ATI Speed up disabled. Fast writes and Sideband I had disabled until I got the OC I wanted and then I enabled them without a problem. You don't want to have anything that might cause instability enabled when you are overclocking as it just confuses things. If you reach a stable overclock and enable them and have instability you will know exactly where the problem lies.mattyhayden said:Very interesting?
Speed up NV/ATI, ? Fast writes ? Sideband On or Off ??
turbotoy said:Can't say I am a big fan of 1.9. After switching from 1.9B to 1.9 oem my coputer is acting all kinds of weird. I turned it off for the night then this morning I had to reset bios to get it to boot. It seams as soon as I change cpu voltage to plus 5% things go wrong.
I hope by that you don't mean that you were overclocking when you flashed it to the new bios because that's not a good idea. (I have done it by accident and gotten away with it but it's not a good practice) Good luck with the overclock.turbotoy said:Okay when using a known stable bios setting on 1.8 then flash to 1.9. no boot. I am having to find a stable voltage and OC all over again. Besides that it looks okay. (unless I can't get back to where I was!!!!!
I agree with you about stability,(I Prime for 12 hours) but I figure it never hurts to be overly cautious.turbotoy said:I am of the opinion that if you can't do everything you want overclocked then that overclock isn't stable. I have alwaysed flash my boards overclocked. But all my boards pass minimum 24 hours prime stable then I memtest 24 hours just to be sure.
Agreed. Thats what tin foil hats are for.rseven said:I agree with you about stability,(I Prime for 12 hours) but I figure it never hurts to be overly cautious.
Are you making fun of my hat!!! You should see me seal a room with duct tape.....lolCheator said:Agreed. Thats what tin foil hats are for.
Bhugarov said:I'm still using v1.8 and the 5% always causes problems booting no matter what the other settings are, really weird. I heard others say that they have problems with the 5% over as well.
Hoot said:I've been running at 1.55 + 5% which nets me 1.55-1.57V measured at the socket and it's just fine for my setup and overclock. Just FWIW
Hoot
Hoot
MoPMatrix said:Why use 1.55? I thought none of the settings over 1.45 worked?
