- Dec 1, 2007
- Near Toronto Canada
Any reason you don't use a rear fan? That will help lower case temps by exhausting the hot air from your heatsink.
Hmmmm, does closed loop cooling count???
This is awesome. I love your no outflow idea. Any reason you 'lean back' some of your fans at the front?
Noticed most of you have a push/pull setup. I have a Zalman with a stock 120 MM fan on it. Any recommendations on how I can improve on this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118059
The Turboloota.
Tried to do something about the 560TI temperatures with the fan under it but no change :/ idling at 45c is quite high imo @ stock, sometimes it's running under 40c depending on the position of the case but I just think that it's bugging etc. What do you think about the temperatures?
In my tests on the Megahalems and on the D14 I have not seen much gain come from a pull fan. Yet if you remove your rear grill, air will leave your case without resistance, and a pull fan on your heatsink will entrain the case air and pull it along as it leaves the case.
You haven't specified your case. You have too many devices in your 5.25 bays to put an intake fan there, but if you have space for a top intake that can push air down in front of the heatsink, you can do that and improve the cooling your heatsink does.
Here is my case. I have a 140 mm top fan already
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
I am not pulling bad temps now but if I can squeeze some more life out of my system it would be worth it.
Your load temps are more important than your idle temps.
One thing you can do is to remove the slot covers from your backplane. That will give the air an easier way to get out. In my own case, since I have a nibbler I just cut out all the pillars between the slots, so the slot space has no impediments to airflow.
Yes I know, just comparing the idle temperatures with geeks3d test and they were having 33c idle stock. Ofcourse when in closed case the temps will rise but still, from 33c to 45-46c? I'm getting 80c+ after one min of furmark so I think I've got some temp problems. 86c after 2mins.
