- Aug 5, 2002
Throughout the years I've been doing distributed computing to varying degrees. The strategy has been to optimise cost. That has included at times using the PSUs that most forums will tell you to run away from. I've never had anything die from a PSU failing, other than the PSU itself of course. On the cheap PSUs, after running a year or two under load 24/7 the system may go unstable, probably saggy voltages but I never measured. Replace and away you go again. One of these low cost PSUs costs a fraction of what is usually considered a good one. OTOH I can't recall the last branded PSU going bad, and some of mine are really old now. For example, I still use a Corsair TX750 which was originally bought for my Sandy Bridge system, and that isn't the oldest. I don't tend to buy cheap PSUs any more, unless it comes with a case or other system, then might as well use it if I have it anyway.
Yes PSU's can last a while, cheap ones fail much quicker and seem to have other issues when they fail as well. A co-worker has done over the years replacing a cheap PSU's low end branded PSU or no-name PSU every 1-2 years because of power issues in the area causes major issues with some electronics in his house and its actually wreaking his system slowly each time. It actually toasts the PSU, to the point I can't even jump start it. Failed USB ports, lan ports, SATA connectors, PCI-E slots, dead HDDs, dead DVD drive.. The list goes on yet the PC still does "work". He can get a new PC and it fails quickly so its not components as they are quality system components that I've recommended and would personally use, excluding the PSU of course. While recently (3 years ago) I finally convinced him to switched to a higher end branded PSU that was a whole $20 more... and zero issues with a system that has a few USB ports failed and 2 of the 4 SATA ports gone from a previous PSU that failed. That was just one experience, I have seen a few other PC's where MB was toast because of a failed PSU over the years. I'd say your lucky that you've haven't had anything fail due to a PSU going out on you.
I would think majority of people, at least us enthusiasts, that when we upgrade a PC the PSU might last more than just a single build. Where it might see more life then some other PC's that might only be used for a few years before being replaced.
