- Jan 10, 2012
the one board that caught fire was in fact my own fault (voltage and booze are a fun but dangerous mix).
...voltage and booze are a fun but dangerous mix.
Nope, there's no way that is possible. (The temperature)
Temp sensors within FX CPUs read about 20c low, so you were around 70c.
That made me laugh
Measured with probe?I don't think so: socket was topping@63°C.
where can i point mt IR temp probe and read the cpu temp if the silly thing is all covered up with waterblock?
or should i give up on that and pull the case side and probe what i figure is the bottom of the socket?
Silicon is very good at conducting heat. I never said you were fooling the sensor, but you are cooling that area under the CPU.
However the surface of that area when you are cooling it from the backside isn't as representative of the real CPU temp than it would be when the CPU was effectively heating it...
In both cases though that spot is a little less than the real CPU temperature.
Gigabyte boards read 8-10c low on socket sensor. The ASUS boards are close.
