Going to be upgrading to a i7-2600k today, im mostly a gamer (still wondering if i should get i5 2500k if it overclocks better) - from this websites list - which cooler would you use for the i7-2600k?
I'm hoping for a 4.5 - 5Ghz overclock, i dont need the absolute lowest temps - just within a comfortable margin of operating spec
http://www.memoryexpress.com/Category/CoolingCPU
Are the closed looped water coolers still the way to go? (I used to use the Corsair H50 push/pull and it was pretty good)
This is the case ill be getting Coolermaster HAF-X 942
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119225
THe sweet spot price wise would be between $50-70 but i wouldnt mind going up to 80-90 if it was worth it.
Thinking either
Antec Kuhler H2O 620 CPU Cooler or
Hydro H60 High Performance CPU Cooler or
Noctua NH-D14 CPU Cooler SE2011 (kind of expensive tho)
Thanks!
Thinking either
Thanks!
