- Sep 13, 2011
I'm torn between :
Zalman CNPS10x Performa
http://www.frostytech.com/articleview.cfm?articleID=2498
Cooler Master Hyper 212+
http://www.frostytech.com/articleview.cfm?articleID=2419
I'm leaning toward the CNPS10X because of the heatsink base surface which is very smooth according to frostytech which prove to give very good performance over the other heatsinks. And as far as applying thermal paste goes, it would be a lot easier to apply it on the Zalman and create a good contact between the CPU and the heatsink....
I also like the fact that the Zalman come with a resistor to reduce speed and noise. Still, the Cooler Master seems to be more quiet at full speed than the Zalman.
Finally, I'm a bit lost about which one to choose. I feel like the heatsink base of the 212+ could cause problem when applying thermal paste because of the gap between the copper pipe and the aluminium base. Also, the installation of the Zalman seems a LOT more easier than the 212+.
Do you guys had good experience with these heatsink ? Which one would you recommend ?
Thanks a lot
Thanks a lot
