- Dec 25, 2004
I've got a friend who has a LGA 775 MB that seems to no longer be able to handle Ethernet. She has tried 2 different PCI-E Ethernet card, plus the onboard port and none of them work, or will let her install drivers. She has even reinstalled the OS on a wiped and reformatted HD, so it is unlikely to be an software issue.
I don't remember which CPU she has, but it is either an E8400 or a Q6600.
Her budget for the fix is $100 or less.
She can get a replacement board on Newegg, but the only ones that are the same type RAM are ASROCK for about $70.
There are some 1155 boards that are available for less than $50, and the low end 1155 Celerons are about $50. I'd be willing to get her a HS/F & RAM to go with it so she has a much newer system, since that would put her over budget.
Which would be the better option, given the OS is Vista 64bit?
Or would I have better luck in our classifieds than either option?
