Hi! I'm currently building a new rig, and have some questions about memory. This is only my third self-built computer so far, so I'm still a bit confused about this and that
My general specs will be:
Intel i5-750 2,66Ghz
Asus GTX460 1Gb DirectCU
Asus P7P55D Deluxe
Corsair TX-650W
I can't decide which one of these two G.Skill kits to buy, because I'm not sure how much the latency affects the kind of set-up I'm about to build. The CL7 is more expensive of course, but because I'm on a tight budget I would like to know if the difference in latency is only minor, or if it really gives a noticeable performance boost (in which case I will buy the CL7, whatever the cost).
4GB Dual Kit Ripjaws DDR3-1600 F3-12800CL9D-4GBRL 9-9-9-24
http://www.gskill.com/products.php?index=222
or
4GB Dual Kit Ripjaws DDR3-1600 FC-12800CL7D-4GBRM 7-8-7-24
http://www.gskill.com/products.php?index=243
I read somewhere that AMD builds are greatly affected by CL, vs. Intel builds that perform mostly on frequency. Is this correct?
Btw, I know i5-750 only supports 1333Mhz, but I'll OC both the CPU and RAM, so I hope there will be no problems there.
Thanks in advance!
Asus P7P55D Deluxe
Corsair TX-650W
or
Thanks in advance!
