- Feb 1, 2005
So I bought this kit wayyy back in the spring of 2011. 4 sticks of 4GB rated at (tCL, tRCD, tRP, tRAS) 8-8-8-24/DDR3-1600.
Series: RipjawsX
Memory Type: DDR3
Capacity: 8GB (4GBx2)
Multi-Channel Kit Dual Channel Kit
Tested Speed: 1600MHz
Tested Latency: 8-8-8-24-2N
http://www.gskill.com/en/product/f3-12800cl8d-8gbxm
For the longest time, I was completely content running it at stock speeds. It wasn't until around last summer that I finally attempted a RAM overclock.
Without much of a hassle I was able to hit DDR3-1866 (at 10-10-10-28) with just a tad of added voltage (1.510v). This is what I've been using ever since.
Over this past weekend, I read some articles about this particular RAM coming pretty close to hitting speeds of DDR3-2133, so naturally, I wanted to see how close I could get to reaching those speeds myself.
After spending a lot of time playing around with incremental combination changes of various voltages and settings, I was finally able to boot into Windows at DDR3-2133. That was the good news.
The bad news? Unfortunately not too long after, Windows locked up on me and I was right back in the BIOS further investigating what went wrong.
I should probably mention the settings I used to achieve DDR3-2133. They were 11-11-11-34 (everything else set to "Auto,") with 1.530v.
I know at these higher clock speeds I have to relax my timings, and I thought I did because up to this point, this was the only combination that got me into Windows.
Therefore, my question is simply this: which specific category (tCL, tRCD, tRP, or tRAS) would most likely yield the stability I'm looking for with such a large overclock? What should I concentrate on tweaking the most. I feel like I'm right there...
Series: RipjawsX
Memory Type: DDR3
