- Jul 6, 2011
- Upstate SC
So I've been looking at motherboards, which is probably what i have lined up as my next upgrade, but I still have a lot to learn. A friend pointed out the 99fxa-UD3, but I want to know the difference between it and its big brothers, the ud5 and ud7.
Also, I've seen a few threads down below this one about "Vdroop" and "Vdrop" and I'd like to know what these are and if I should worry with them.
I use this computer to game, but I also do some benching on it (this isn't important, it's just because it's my only rig) and I will have an install I use for work (since my laptop pooped out on me >> ) so I'll have AutoCAD/AlphaCam/StoneVision and my programming suites, I usually use VS2010 Pro. I want to overclock as far as possible for daily use ( I will be upgrading the cpu after the motherboard.. probably when BD comes out and I can get an 100t for cheap )
but ulitmately what I want to know is.. is the price difference worth it? and if you know any others I may be interested in, do tell.. especially if they're all black
links..
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128509
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128508
links..
